주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Which Part Isn't Working?
Hello. I have an iPhone 6, and about three months ago, Wi-Fi began to feel really weak, it would disconnect even when standing next to the router.
More recently, the front camera AND the ear receiver stopped working. ( I now have to put calls on speaker to hear them).
My question: is it possible that one broken part have caused all of these problems?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
No it wasn't dropped.
Is it possible to replace the flex?
댓글 달기
답변 3개
선택된 답변
The front camera and ear speaker share the same flex, so it's normal that both could fail at the same time. The WiFi antenna is in the same area but not physically part of the same flex. It's actually in the housing instead of embedded within the screen assembly. Did something happen to the phone recently, such as a heavy drop, a repair or contact with water? Those are the kinds of events that could cause multiple problems.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
이 답변은 원래 다른 질문의 답변입니다.
There is an inter connected antenna on the underside of the board that may need to be reseated. Unless you are extremely diligent with the screw and all of the small parts I would suggest getting some help with the repair.
If this doesn’t solve the issue there is also microsoldering options but we can cross the bridge on that after the antenna is checked.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
You mean to reseat the antenna. Not replace it? Can you please refer me to the guide.
here: iPhone 6 Wi-Fi Antenna Replacement it says replacement, but you can use this guide to get to the part.
댓글 달기
Like Scott says replacing the wifi antenna is your first option ,it's common for this part to fail and cause weak wifi.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
AaAa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 65
