주요 콘텐츠로 건너뛰기
The Dell Latitude E6400 was Dell's mainstream corporate 14.1" notebook introduced in August 2008.
40 질문 전체 보기
Activating the Bluetooth wireless switch
I have been trying to tether my iPhone to my Dell Latitude E6400 using Bluetooth. When I click on the Bluetooth icon, it tells me to activate the wireless switch. How do I do this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 56
댓글 18개
i have switched on the airplane mode so it stops all wireless connection,bluetooth...but i cant to off it i tried all known possiblities fn+signal symbol,setting al is greyed out
hello guys I'm here to help you guys
please update the drivers
and please refer the following link just copy and paste on the browser after downloading you can use Bluetooth and also can view in device manager
http://www.driverscape.com/manufacturers...
How can I instail my bluetooth?
I have dell latitude e6400 Laptop and having problrm with blutooth.. bluetooth indicater light is on but there in no any bluetooth icon anywhere in the laptop in divice manager or control panel etc
mine too
please help
댓글 13개 더보기
댓글 달기
답변 5개
선택된 답변
First, be sure you have the Bluetooth option; it is not standard equipment on your model. You should have a Bluetooth indicator light above the F1 key if yours came equipped with Bluetooth. There should be a key sequence marked for it on the keyboard. I believe it is Fn+F2 that will switch your Bluetooth wireless on and off. Your WiFi wireless switch is on the right, above the headphone and microphone ports (next to "Dell Wi-Fi Catcher" button).
해당 답변은 도움이 되었습니까?
점수 40
댓글 14개:
Good answer.....+
Thank You. It is working now
still cant find it
still bluetooth indicator light above F1 not on..
plz help me..
my light will not come on iv pressed fn+f2 as well
댓글 9개 더보기
댓글 달기
Turn on your wireless from wireless button and bluetooth will also turn on with this.
해당 답변은 도움이 되었습니까?
점수 15
댓글 1개:
Vergo, read the comment made by Kevin McConnell (the OP), March 23, 2011. Good answer to a very old and resolved question
댓글 달기
Firstly you need to make sure that whether your Bluetooth is properly installed and as far as the switch is concerned the check on you keyboard from F1 to F12 where you can see the Bluetooth icon. So all you need to do is just to press Fn key and then hold the exact Bluetooth activating key.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
bluetooth is not turning on in my laptop
댓글 달기
you may not have the bluetooth driver installed. Go to dell support, look up the 370 minicard under wireless devices, and download that driver. Once it's installed you will have the tray icon where you can connect your bluetooth device. Here is a link:
http://www.dell.com/support/home/us/en/1...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I have a Dell latitude e6430, and it did not come with a Bluetooth card. There isn't a Bluetooth symbol on my keyboard anywhere can I install one? And if I can will a Bluetooth card from a Dell Latitude 6400 be compatible?
You can always install a USB dongle to add Bluetooth functionality. And yes, they make WiFi cards that include Bluetooth so that is also possible. I'd go for a newer one since the lat e6400 is like 10 yrs old
댓글 달기
i have a dell e6400 the blue bluetooth icon is on, bluetooth card is in, i have windows 10 i cannot find bluetooth software please help this is extremely fustrating
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kevin McConnell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 24
30일 전: 84
전체 시간: 264,347
