주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20001 질문 전체 보기
Why is the MBP not charging?
Hi all.
Helping someone out with her macbook pro, all signs point to (99% certain) to the DC board connector.
The issue is the Macbook pro doesn't charge battery, or power on. (with AC connection alone), nor does the LED emitt at all. Yet with the AC disconnected and the battery in, the laptop runs just fine.
This points me directly to the DC in board as if it were the logoc board the mac would have problems on battery too.
The Macbook is out of warrenty
I'm simply asking just for conformation... Am I correct in that a replacment DC logic board would sove the issue ?
Just for the record, yes... i have reset the SMC ... and have replaced with new power adapter.. Still no good.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
Sounds like the DC-In board is correct to me. Please list the last three letters of your serial number to correctly identify your Book and get you to the right part and guide.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Seems to be the MOSFET. It is possible to replace it but you might have trouble finding it. If you cannot find it then you will need to replace the motherboard. I say give it a shot and maybe you get it to work :D
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Sounds like your I/O board is bad, that is the only way that the battery can be charged. Does the indicator light on the Mega-Safe power connector lights up bright when connected to that port? if not, then replace that board first before you do anything else to it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
technet147 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,035
