주요 콘텐츠로 건너뛰기
2015년 6월 출시 Android OS, v5.1 8 또는 16GB 저장 용량, microSD 카드 슬롯
45 질문 전체 보기
I can't turn on my phone. Why?
Hi I buy galaxy j5 at 2015 and worked fine till the battery got swollen around second month in 2018. The phone was discharging very fast and charging very slow and once when it get discharged won't turn on when i let it to charge. So I thought it was bad battery so I buy new one but still it won't turn on even the charging animation when turned off. So I was searching how to unbrick hard bricked phone and I found is jig So I order one from aliexpress but it didn't have the fifth contact I think so it didn't work so I buyed new one and I found old galaxy mini so I tried is jig on this phone and the new usb jig worked but for j5 didn't. I really don't know what to do now I'll be happy for every suggestion. Thanks Dalibor. Ps:sorry for mistakes I'm Czech.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@dalibortrampota you'll have to first identify which version your phone is. Something like J500F/J700FN (Global Single-SIM); J500F/DS (Global Dual-SIM); J500G/DS (Malaysia, Indonesia, Singapore, Thailand); J500Y (Australia, New Zealand); J500M (LATAM); J500M/DS (Brazil); J500H/DS (Philippines, Russia, Ukraine) will help. Not sure what jig you purchased on Aliexpress but I'd start with something like the Samsung troubleshooting flowchart.
Of course, you can always dig a bit deeper for something like this
Since you originally had the battery swell up, I would also consider a failed PMIC. Samsung has a separate repair guide for that Repair-guide-for-J500-charging.pdf
Update (04/14/2018)
component location for the No-Power chart
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
@oldturkey03 i have J500FN and the first picture the flowchart i really dont understand to
*Most of all option
@dalibortrampota not sure what you mean by not following the flowchart. You need to measure the components listed in that image.
댓글 달기
have you tried to connect it to your PC?
can you go in download/recovery?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dalibor Trampota 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 13
전체 시간: 852
