주요 콘텐츠로 건너뛰기
Decorational lighting used around the holidays.
How to fix a broken fairy lights
Hello,
I have a fariylight string which was working with a solar panel, however it stopped working suddenly, I don't know why, I opened it, and there is a battery that gets charged and then is used to supply the lights,
now what I want to do is, remove the solar panel and directly connect the lights to the battery,
I tried that, now I have two wires from the light, I connect either of them to the battery but it won't work, I used a tiny resistor from another device but it won't work too.
I watched a video where I can connect the two wires to a usb but it didn't work too.
I don't know if there's something wrong in the way I do it. I don't know if there is a positive wire and negative one but I've tried both and it won't work.
what should I do? and know that I've got no experience at all in electronics but I'm trying to.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Clean or bypass the on/off switch if there is one. Clean the battery terminals. More detail is on youtube now. You can test it with a regular battery. Just don’t get light on the solar panel.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Atheee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 80
전체 시간: 3,334
