주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Doesn’t turn on
Hi so I have a iPhone 6S, that recently got into a boot loop, and now it doesn’t even turn on. I tried doing a hard reset, replacing the battery, and when I plug it into iTunes it tells me to restore, and after clicking ok, the restoration process begins but it always stops and gives me error 15. I appreciate any help. Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
You sure it's error 15? I can't find any info on that (1015 however means your phone is jailbroken and permanently bricked)
댓글 달기
답변 1개
I've worked on hours on iphones that have boot up issues and some can be cleared by connecting to iTunes and some can't. Its a software glitch that can't be repaired no mater if the battery is replaced screen or anthing else. At that time its time to replace the phone.
If you tried going into Recovery Mode the last resort is DFU Mode: I have attached an artctle that explains and also helps you to do that just click on the link.
https://www.ikream.com/2018/02/how-to-fi...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Luca 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 50
