주요 콘텐츠로 건너뛰기
Google의 첫 번째 Android 스마트폰인 Pixel XL(모델 번호: G-2PW2100)은 2016년 10월 20일에 출시되었습니다. 5.5인치 AMOLED 디스플레이, 3450mAh 배터리, 32GB 또는 128GB 스토리지 옵션이 있습니다.
Pixel XL not turning on
I was browsing fb and suddenly went out. Tried charging but won't turn on at all. Called Google Tech Support but all diagnostic procedures didn't work to make it turn on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
If the phone is not turning on you can try a few methods to try and fix it, but because the phone is off, it is going to be more difficult than any other problem
because you are not getting any clue of what is going on. The first thing I would do, is try and see if the phone is charged, or if it will charge. If you hold down the
power button on the right side it may show a totally black screen with a battery indicator telling you are out of battery. The second thing I would try is looking for
signs of water damage. I have had the Google Pixel XL for over a year now, and I had one experience of dropping my phone in the toilet (long story) and it would not
turn on and the screen would not respond or turn on. What I did, was I dumped a bag of rice in a small container and buried the phone. It actually worked after a day or
two and it actually surprised me. My last tip is trying to reboot the phone. You can do this by holding the volume down and power buttons simultaneously; when the android recovery screen pops up, use the volume down and up to select different options. Select the "Restart bootloader" option and press the power button. If these solutions did not help you, I suggest seeing an expert at the store you got it or stop by a local repair shop.
How to reboot a Google Pixel XL:
https://support.bell.ca/Mobility/Smartph...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
manny elizes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 2,290
