주요 콘텐츠로 건너뛰기
Samsung Galaxy S9은 모델 번호: SM-G960XU로 식별됩니다. 2018년 3월에 출시된 9세대 Samsung Galaxy Series 입니다. 색상은 라일락 퍼플, 미드나잇 블랙 및 코랄 블루가 있습니다.
137 질문 전체 보기
Can I replace my screen with an s8 screen?
Hey, I got my phone 2 weeks ago and already managed to smash the screen and break the digitizer. I was wondering if I can purchase an S8 screen and digitizer and replace on my S9? As far as I know, the only difference between the two screens is how bright it can get but that doesn't really matter to me. Will the connections be the same and will it be compatible?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
No and their not the same physically and technologically.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
I've been using my s8 with a s9 screen for over a year with no issue
Seriously? I plan to put s8 screen on my s9 with a broken screen. If what you say is right, it will work.
did you finally put the screen? it works?
댓글 달기
They are actually tje same the only diffnis the frame if you can get the screen off the frame without breaking it it plugs in and works fine I've done it on my own I use the s9 to fix my
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
You did this process yourself ?
Andrew. Did it really work? Or do you have the correct screen, and thought I had the wrong one?
댓글 달기
The answer by Ben is 100% correct they’re technically different and even though they have the same fit and the connector is the same look at the back of a S8 and S9 digitizer and lcd you will notice the difference of certain resistors and or capacitors and certain other things like if you look at the little gold dots near the bottom on the back they’re different. I’ve worked in shops for years and people make this mistake all the time when buying their own parts because the image online will show s8 screen when your trying to get a s9 screen. Even in the shops newer guys after 6 months of constant repairs would sometimes make the mistake but it can cause damage like shorts and even blow out chip/resistors/capacitors I have had it happen to people many of times so if you think you have one of the opposite screens on your phone and it works fine your most likely using the correct screen cause like he said technology is different and there’s subtle difference on the back like look at the placement of the gold dots arranged near the bottom on the back of the screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I would post a pic but just search S8 lcd replacement vs S9 lcd replacement on google images and you find a pic that shows all The backs of the s series and you will notice the difference if you can get a close loom
댓글 달기
Can I put my Samsung Galaxy s8 screen on a Samsung Galaxy s9
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Laimis Minelga 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 27
30일 전: 98
전체 시간: 4,735
