주요 콘텐츠로 건너뛰기
2014년 12월에 출시한, 여러 모델 번호로 알려진, 아시아 시장을 위한 Samsung의 Android 스마트폰.
118 질문 전체 보기
Can I turn my phone to back up data
I have Galaxy A5 2017 and i think the charger port is broken it does not charge, the past few days it was hard to find a spot to start charging and now it does not charge at all ,but i have really important files on the phone and can i turn it on in some other way just for a few minutes to back up the files before i take it to service? Thank you in advance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Do you have another samsung at all that you could connect your battery up to and charge it? Obviously you'll have to line the gold pins up on the battery but it will charge, otherwise you could take it to a repair store and just ask them to charge it for you? Thats a service i offer so i'll assume most are the same.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@will91491 this will only work if she has an exact 2015 Samsung A5. All Samsungs are built from the ground up and all use different batteries. Also, this requires disassembling the phone. If you were going to to do this on an A5, you might as well repair/replace the chargeport!
댓글 달기
귀하의 답변을 추가하세요
Samsung galaxy a5 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 39
