주요 콘텐츠로 건너뛰기
In-ear noise isolating headphones with ControlTalk microphone. Made by Monster as part of the Beats by Dr. Dre line of headphones. Released in 2010. Model number: 0000441731.
9 질문 전체 보기
ibeats wire snapped for no reason, can I re-attach it?
I bought these last summer and for some reason the area that i put blue linings around snapped off, now i can only listen to music with one earphone instead of 2.
I really want to listen to music again with both earbuds and my question is how can i reconnect the wire and make it work again, and if it is even possible?
i used to cut wires and re-attach them on other electronics so i guess this will maybe work for my earphones too.
thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You can try, but it is not sure you will be able to fix it. You will need to find out if there is any issue in the cable first, if not, just reconnect it and make sure it stay there. For the 95% of the chances, it will not work, but trying does not harm!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I will have to open the small box where the cable gets divided in two and reconnect it there, be carefull with the other earphone side cable
댓글 달기
귀하의 답변을 추가하세요
Julian Blue 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 280
