주요 콘텐츠로 건너뛰기
다양한 장신구 수리 안내 및 지원.
3 질문 전체 보기
very hard setting, very clear epoxy glue
Hi all. Can anyone recommend an epoxy glue that I can repair a cracked and chipped agate stone that is set into an expensive ring. I really dont want to have to replace the stone as its an irregular shape so fitting a new stone to the ring will be too hard. I want to try to mask the cracks and missing spaces with a tough but clear glue that wont yellow with age. I anticipate mixing it with acetone to give it additional flow. I found something very expensive stuff but before i go that route Id appreciate seeing if anyone has any recommendations. Araldite was too opaque and yellows I think. Many thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
had a look and can find this but not sure if its what your looking for or not https://www.amazon.com/Epoxy-330-Water-C...
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Thanks so much for looking. I'm in the uk and they dont ship to uk. will look and see if I can find it on the uk amazon
what about car window chip epoxy
good idea. I wonder if I can get it in small quantities though. Its the shipping that seems to send the cost up. I found the 303 glue but even on uk amazon the postage is 3 times the price of the glue! Thanks for your input
댓글 달기
Hi I have great success with UV resin it uses ultraviolet light from a UV torch or even the sun, you can get it on Amazon, hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cecilia Leete 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 482
