Motorola MBP33 baby camera disassembly
Looking for a guide of how to dismantle the baby camera for a Motorola MBP33 baby monitor please. Found a few for replacing the mic and speaker but I'm hoping to replace some IR led's as only 3 out if 9 work giving a dark image. Have had it apart as much as the base off but wonder if anyone has managed to disconnect the 2 small multicore plugs as they won't disconnect and don't want to over do it and break any thin wires. Looks like the plugs have to disconnect to allow the camera housing to be removed to allow it to be split to get access to the camera led's, so any advice would be much appreciated thanks
좋은 질문 입니까?
댓글 1개
I don’t have a solution for you (yet!), but am interested in if you have disassembled as far as splitting apart the camera housing? Mine was dropped and the camera circuit board is loose inside the spherical housing. I need to separate the two halves so I can reseat the camera circuit board. If I can get it apart maybe I’ll see your two multicore plugs and figure out how to disconnect. Thanks.
Terry Brown 의
