주요 콘텐츠로 건너뛰기
The Asus Zen AiO Pro Z240IC is an all-in-one desktop computer known for its 4K, ultra high definition screen and one terabyte Hard Drive. With plenty of processing power and memory, the device received the PCMag Editors’ Choice award in 2015.
22 질문 전체 보기
Replacement for cracked screen
I had a problem when opening the aio and I cracked the glass of the screen.
does anyone know if you can find the replacement for the external glass part? the screen that has the touch?
I cracked it when opening and everything works, but it has the cracked lines and I would like to replace this screen.
please point me to where I can buy it.
thank you!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
A lot of times they will have different models of the glass itself with touchscreens. It would be better to remove the screen if you are comfortable with doing so and look on the glass (probably will have a ribbon cable attached to the glass somewhere) and read the model numbers there and do a search off that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
gasguirre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 392
