주요 콘텐츠로 건너뛰기
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
90 질문 전체 보기
How tight does the cap on the coolant tank have to be?
I replaced the coolant reservoir tank . The cap snaps on ok but you can still turn it very easily. Not tight enough to make a tight seal? Still loosing a half tank of coolant every 2-3 days.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Usually you have to press it down with the heal for your hand and turn it to lock it place. Do not do it when the engine is hot.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
So it looks to be just a simple snap cap, if that is the case. Then it is just a press fit until it snaps over the rim. Coolant should be half between cold and hot mark at rest.
If you are using green coolant, most likely. Then look for coolant traces around reservoir, check all hoses and connections for condition and tightness.
Find your water pump and check that there is no fluid leaks around that area. Does the fluid pool under car overnight? I'd assume it was the water pump or a failing hose.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mary Mitchell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 2,464
