주요 콘텐츠로 건너뛰기
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 질문 전체 보기
IPad 5th gen battery issue
Ok so I had a guy bring me an iPad 5th Generation in to my shop with a cracked Digitizer to get repaired. While testing it I noticed the battery shows 1%, so I plug it in to charger and once the charger recognizes it shoots to 100% and will stay on for about 10 seconds then shuts off and turns back on at one percent, within a few seconds shoots back up to 100% and just keeps cycling through.
It was doing this prior to working on it, I went ahead and replaced the Digitizer but cannot figures out what could be causing the issue.
Do you think it’s possibly a bad battery? Software? It has an update available but shuts off before it can update, thought about trying through iTunes but don’t want to do that and then the iPad get stuck in recovery if it shuts down in the middle of an update
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
UPDATE: upon further inspection I can confirm it’s most likely a bad battery. I spoke with the customer and they said it stays plugged into a Square register dock 24/7 which leads me to believe the battery is shot
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
chad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 957
