주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 질문 전체 보기
Leaking water on the bottom
I Took the back cover off I ran the washer empty and there was no water leak .then ran with a load and there was water leaking . I seen the water dripping frim the bottom in spots but couldn’t tell where it was leaking from. Where would the leak be coming from and how do I fix ( you tube i’m Sure ) please and thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Maytag washer ,bravos xl leaks from bottom what could be wrong.
My maytag leaking from bottom when it on spin
댓글 달기
답변 2개
가장 유용한 답변
Cause 1
Drain Pump
The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. The drain pump is not repairable—if the pump is leaking water, replace it.
Cause 2
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 3
Tub Seal
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
Our Maytag washer was leaking intermittently. Checked all the above mention spots for leaks and found none. Found there is a siphon break on the pump discharge where it goes through the back panel that was not always sealing properly when under pressure. Cleaned it of lint with a tooth pick and blew water through it until it would seal when sucked on. It now seals properly
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Can u please specify where the siphon break is on the discharge pump? Do u have a photo of that?
댓글 달기
귀하의 답변을 추가하세요
Ryan Buil 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 88
전체 시간: 37,162
