What is the best tape or glue for rear glass and digitizers?
What is the best way to reattach the digitizer and rear glass on samsung galaxy devices S5 and up?
좋은 질문 입니까?
좋은 질문 입니까?
I use ZHANLIDA B-7000... its glue... not tape...
해당 답변은 도움이 되었습니까?
is this permanent though? if i have to replace a part on phone again while i be able to fix again?
its really strong glue, like chemopren base... but with isopropanol posible remove
perfect thank you i will try this!
usually 3m double side tape
해당 답변은 도움이 되었습니까?
do you have a link to where i can buy some that doesn't cause the screen to lift
Kristina, here is an adhesive made for the s5. It is only $5.99 and you can order it right here. Enter the Item Code below in the search bar and you can check it out. I hope this helps. Please let me know, Thanks, John
Galaxy S5 Touch Screen Adhesive
Item code: IF236-043-1
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 306
