주요 콘텐츠로 건너뛰기
Intel Desktop Board D945PSN supports the LGA775 socket released in 2005.
6 질문 전체 보기
Computer won't come on and it freezes
I'm not sure what Intel hardware is in my computer but it is some kind. Most of the time I have to restart my computer or it wont work and when I type I see nothing and then all the sudden what I had typed has appeared and sometimes it just freezes and I have to just turn it off to get it going again or it just crashes.
Do you know how I can fix this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 6개
Hi,
What is the make and model number of the computer?
What OS is installed, Win7, 8.1, 10 etc?
What happens when your computer "won't come on"?
After you switch it on how far does it get before it "stops and freezes"? Do you see the makers splash screen logo, do you see the Windows starting screen, are there any beeps during startup or error messages on the screen?
Does it only happen when using one particular program or all programs where you have to type?
does this only happen when you enter text into any fields? does it happen all the time?
I have no idea what model the is but its Windows 10. The computer takes about 3 minutes to come on, and to get to the internet I have to restart it. Sometimes I am using it for an hour or so and it just freezes and I have to manually turn it off and sometimes it happens earlier. I get a message that says "error stopcode: unexpected store exception. Yes, when I type into any fields I have to reenter text most of the time. and it happens with all programs.
I got a message that said "stop code" so I did a DSM/Online/Cleanup-image/Checkhealh and after that I got a message that said there were no errors. I am still getting the problem.
@ Sheila
If possible, take pictures of the issues, stop code page and computer made, we will try to help you.
댓글 1개 더보기
댓글 달기
답변 3개
선택된 답변
Hi,
Here's a link that may be of some help.
Do Steps 1, 3 & 4 Do not do step 2 as it involves downloading and installing 3rd party software which may or may not be a wise move.
Do one at a time and see if it resolves the problem before trying the next step.
p.s. The make and model number of your computer should be written on a label at the back of the computer or underneath, unless you have a custom built one.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I couldn't get the link my computer said it was a PUP and it was blocked.
댓글 달기
가장 유용한 답변
Make first clean reinstall the windows.... whrn still frozen i think is KO capacitors on motherboard...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
try downgrading your OS win. 10 has now technical issues, you must reinstal previous version of windows like win-7 or win-8
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sheila 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 15
30일 전: 26
전체 시간: 852
