Whey My Motorcycle is not Starting
I have an 09 Yamaha v star 1100 classic, I have changed the spark plugs , I have replaced the battery, I also replaced the filter but she is not starting what is going on with this Motorcycle....
좋은 질문 입니까?
좋은 질문 입니까?
If it sat more than 4 months with no fuel stabilizer, The most common is a pair of gummed up carbs. Pull the drain screws on carbs. & check for gas. That will also tell if fuel pump is working. If green gas, Carbs must come off for cleaning, Can’t be done with cleaner in tank.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 76
Do you have any spark? Is your air filter clogged? How is your fuel?
sm_vulkus 의
