주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 질문 전체 보기
Very difficult to move in reverse gear.
The truck will shift through all forward gears just fine without any trouble, but when I put it into reverse I have to give it probably around 3000 rpm to move at all. Trans needs serviced bad. Just wondering if that's my issue or if I have something more to worry about. 1992 Chevy c1500 5.7L automatic 4x2.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
If your trans needs a service bad, it might be failing. I'm not sure how many miles you have and how you maintain the car, but by the sound of it, it might be slipping in reverse, so you would need to get a new trans, or get your old one rebuilt. Both are expensive unless you can find one in a junkyard for a good price.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It is probably the transmission/torque converter. I had the same problem with a prior car...it would lose power in reverse. Quickly shifting into neutral and back to reverse made it work momentarily.
댓글 달기
98 Chevy Silverado 5.7
5 speed how come all my gears work and forward but reverse it don't and my tail lights don't
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cole Custer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 32
전체 시간: 915
