주요 콘텐츠로 건너뛰기
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
54 질문 전체 보기
Can not switch on bike after a few weeks pause
Hi, I have not used my Qicycle for a few weeks. Now it can not be switched on anymore. The battery is fully charged (all LEDs are lit) but the display is dead. Does anyone have an idea where to start debugging? does anyone know the problem? I'm grateful for any hint!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 8개
가장 유용한 답변
Have you tried removing the battery from it's seat and then putting it back?
Then turn on the trip computer by holding the on/off button for about 3 to 5 seconds.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Your inner power button must be displaced
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Do you have experience with a malfunctioning power button? It seems like that is the problem I have. I managaged to turn the display on once, after trying a lot, but now in the menu the button again doesn't respond. The up and down buttons do respond as they should. Should I open the controller to see if I can replace the button?
Where is that inner power button located?
댓글 달기
I have exactly the SAME question! 3 weeks off, on the balcony - very hot (I live in Italy)… now display is DEAD
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Same thing happened eith my display. I left the bike outside for lunch. When I got back, the display only lights up but nothing else.
댓글 달기
My Qicycle all instruments are on. Batt is good. Display is good. All lamps work good. But when I hit the pedal, the motor won’t work. Now, it almost 1 year in my room. I went to several e-bike service center. None of them can fix the problem. No parts available in my country. And it seems they are all did not know what happen with my bike. One said about the controller. Another said about the motor. Very confused and make me frustrated. Now, the bike still in other technician. He try to check one by one. Flow of cable, sensor, controller, motor, battery. I just hope he will find the solution and my Qicycle in on the way again to my daily work vehicle.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes, even here in the Phil. parts are scarce to find. Only hope is aliexpress. But many sellers have ran out of stock or are not willing to ship. I traced the company, even though its mostly made in China or xiaomi is a Chinese brand; this "qicycle brand" is actually Korean.
댓글 달기
how do you change the language on the display to english?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
https://3dparts459136784.wordpress.com/h...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello, did you manage to get this problem fixed? I'm having the same issue :(
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I fixed my problem in the end by opening the display/controller thing om the steering bar. Inside a contact was a bit corroded, so by cleaning that it was fixed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tkehrberger 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 23
전체 시간: 1,616
