Why won't my tablet hold a charge?
The battery drains too fast.
좋은 질문 입니까?
There could be a variety of causes for this. The easiest may be that your tablet isn't getting plugged in correctly or long enough or the charging cable has failed. Trickier would be the battery failing, but if you've had the tablet a while or just have extra bad luck, it's not out of the question. Luckily we have a battery replacement guide coming soon. I will circle around and update with a link as soon as the guide is public. In the meantime, try looking at our troubleshooting page here and see if any of the simpler issues might be your cause first. Good luck figuring out your power problems!
EDIT: Here is the battery replacement guide I mentioned.
해당 답변은 도움이 되었습니까?
Dear Delaney, Great short Guide with the added information from the other guides, but like I pointed out in your Troubleshooting Guide, you may need to check the other referenced Guides for accuracy and being appropriate to this Model of LG G Pad X 8.3 Tablet (i.e. the additional hold down screw for the battery). This Guide (like the others) could of used the part number for ordering the Replacement Battery and where you had purchased this part. Otherwise this was helpful.
The one thing that I have learned over many years in IT, devices and software are NOT Stagnate ! Thanks for your work ! !
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 657
