주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone lost battery and now cannot turn on
Hi, so my iPhone 5 is pretty old, and after dying one night, I decided to plug it in. After leaving it out for the night, in the morning I was shocked to find that it had no charge whatsoever, and that after charging for six hours it still will not turn on. Now before you start saying: "Press the home button and the power button simultaneously for 15 seconds" Trust me, I've tried it. Many times, it didn't work, it's sleeping like a log.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Grace...we need some more information....when you plug in your charger, do you get any symbol come up on the screen with a battery symbol ? If not you could try a different charger and cable, if you can borrow one perhaps. If this doesn’t jump start it, you may have a problem with the battery (they do have a limited life span). Good news is that they are cheap and easy to replace (see the iFixit guide on this replacement.)
Lastly you may have a charging port where you plug in, blocked with minor debris (the main culprits are pocket fluff, hairs, wood dust etc. )....all of these can be carefully eased out with a needle or long pin. You may then find your charger will bring up the charging icon and your phone should then fully charge in about 2 to 3 hours.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
When I plug it in currently, it doesn't do anything, it's just black, however, earlier on when it was just recently dead, when I plugged it in there's no symbol, but once I pull it out a charging symbol appears.
I do not have another charger and/or cable, although I may borrow one from a friend after hearing your advice. I will try the things you mentioned, however, and I will update you asap, thank you Malcolm!
댓글 달기
귀하의 답변을 추가하세요
Grace Li 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 45
