주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
My earpiece speaker is not working.
Hi, I have two iPhone 6's where the earpiece speaker does not work. I have changed iPhone screens multiple times on various iPhones so I have knowledge of the procedure. However, after trying to replace the earpiece speakers on these two iPhones with multiples replacements including purchasing replacement screens where they are already pre-packaged/built so all I have to do is connect the cables to the screen, home button ports etc, it's still not working. Everything else for the connection works like the proximity sensor. It's just the earpiece speaker that does not work. Any help? Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
When replacing a iPhone 6 screen it is super common for the proximity flex cable to have a small tear. I would recommend looking over the cable to see if there are any tears. 99% of the time it is a small tear in the corner closest to the connector. However, it could also be a bad speaker, but i have only seen that with water damaged phones.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I bought a brand new screen which is already assembled, so all you do is clip in the cables and tried that and it still didn’t work, but I’ll check later today.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kymani Steer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 34
