Logic Board Replacement: from Late 2013 IG [2.0GHz] to any compatible.
Hi, so I got this MacBookPro11,2 [i7-4850HQ 2.0GHz, 8GB Ram, Iris Pro 5200] but it's water damaged causing the CPU to be capped and the fan running 100% all the time, and having stability issues in general. Although the condition outside is "mint."
My question is, how many boards are out there that is compatible with this exact model? [As far as I've seen would be the late 2013 itself and 2014, while 2015 had a different trackpad connector because of force touch.]
Current board layout: 820-3662-A [820-3662-03] [Same exact one as the teardown guide used.]
좋은 질문 입니까?
