주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
screen lifting after replacement
Hi all,
this question is not only for note 4 but a lot of other brand phones too.
when i replace the screen, i also get adhesive sticker.
now the problem is, after i replace them, the corner of screen is always lifting, it doesn't stay stuck to the bezel.
is it because i am buying $@$*!& adhesive or am i doing something wrong?
i clean the bezel with alcohol before sticking the screen.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Thanks for the input you legends!
Will give that a go :)
Cheers
댓글 달기
답변 2개
선택된 해법
Try adding some axtra pressure to the screen so the tape can really stick to it, if that does not work, try adding a little bit of B-7000 and add pressure to the screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Some precut adshesive already adhered to some screens is not that great. Not all tape and adhesive are equally good for sure. Ensure frame is clean as possible. Using heat before clamping can help. Heat will help create a stronger bond. I use about 270C along a side with a hot air rework station to the point where it's too hot to touch then clamp. Continue this along the perimeter of the device. If the frame is deformed, it can cause lifting and need replaced. Some techs use a tiny drop of glue at the corners.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
nick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 942
