주요 콘텐츠로 건너뛰기
Repair guides and support for the second generation Honda Insight.
Why do the electric passenger windows quit working?
How can I fix the problem of the passenger windows when they stop working. The drivers window works fine but the other three windows suddenly stop. Is there a part that I can replace and what is making that part die?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Does the drivers side switch operate the window on the passenger side?
댓글 달기
답변 1개
선택된 해법
There are many reasons the widow wont work . It could be the regulator , the electric motor, the switch on the passenger door , the switch on the drivers door , but the most common problem is the wires in the door were they pass through the door hing . as the door opens and closes the wires flex and bend and eventually break . Your best bet is to get out your multi meter and do some testing .Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
William Salzwedel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 455
