주요 콘텐츠로 건너뛰기
Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
2704 질문 전체 보기
Why does my subwoofer start to make a rumbling sound at high volumes
I have a cowin ark 4.1 speaker and have been using it for little over a year now. it was working perfectly but i have recently started to hear the subwoofer rattle at high volumes ? any idea on how to fix this? i have emailed cowin 3 times and they never responded
thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
It sounds like a small tear in the speaker cone. It will be visible. Remove the cover to inspect. If it is a small tear, you can probably repair it with rubber cement. If larger, you will need to replace the cone.
Good luck,
Russ
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Typically rattles at higher volume are indications of a problem with the cone not moving properly. This can be a tear in the cone, a rip in the surround or a problem with the spider. The surround is the foam piece around the edge. The spider is the part near the magnet that holds the cone in place. If the cone does not move up and down properly, it will hit the side and cause a rattle. The bottom line here is that the actual speaker requires attention.
Dan
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
arkt0m 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 63
전체 시간: 9,098
