주요 콘텐츠로 건너뛰기
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
147 질문 전체 보기
MacBook stuck in a boot loop
This is the 1st screen that shows up upon turning the laptop on.
This is the 2nd screen. This restarts the laptop and takes it back to the 1st screen.
This is the eventual last screen that shows until you turn the system off or restart it.
It seems the Operating System bricked during the last update after Yosemite.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
This link may help you out, it deals with the Mac reboot issue. How to address a constant reboot loop in OS X https://www.cnet.com/news/how-to-address...
Hope this helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You'll need to re-install your OS as something is corrupted.
Boot up in recovery mode (holding R key when you restart) that should allow you to start. But before you do anything you want to create a bootable USB thumb drive following this guide: How to create a bootable macOS Sierra installer drive or this guide if you have High Sierra: How to create a bootable macOS High Sierra installer drive
The reason you want the external OS installer is you'll need to do a complete wipe of the drive and re-format it. If you have anything important make a backup while you can before you do move forward.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Josh Marx 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,154
