주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Device repair information and troubleshooting for the HP Pavilion g6 laptop.
Computer does not start.
The laptop does not start and gets heated on the left rear side upon charging.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개:
Does your laptop do anything? Do any lights come on or flicker? Do you hear any noises when you power it on? Does the fan run?
Actually i was there to boot windows 10 but my laptop was not taking it and Everytime it gets shutdown during the installation of windows 10. So there were several problems due to that my laptop shut downs like due to corrupt file and then i restarted automatic repair failed ,then tried to roll back the previous windows 8 but it is not completely starting, i mean the login page is not visible(blank) but the screen and mouse pointer is visible. So i need a reboot with windows 10( not premium) and my left side portion sometimes gets overheated, so it requires the fix too.
Why do you try to install it in the first?
Did your laptop used to work hot before?
Estimado , la computadora se calienta por el lado de la ventilación ? si es así hay que limpiar antes de intentar encender , no intente usar una sopladora que tire aire hacia adentro , la forma correcta es sacar el ventilado y limpiar correctamente , si fuese necesario poner pasta disipadora y probar
댓글 달기
답변 1개
You could try to clean the dust and replace your thermal paste. Overheating is the most common issue for laptops when they boot and shut down after a while.
Although in desktops it’s quite easy to clean the dust and re-apply thermal paste, in laptops it’s a bit harder. If you don’t know how to disassemble it, it could become really troublesome.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vicky singh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 210
