주요 콘텐츠로 건너뛰기
Repair and disassembly guides for the Huawei Honor smartphone line.
311 질문 전체 보기
Touchscreen fully works for 10-30 min then fails partially
I have an Huawei Y6 SCL-L03 (Honor 4A), it works completely fine for around 10-30 min but then the touchscreen stops working, after pressing two time the power button (Turning off and then back on the screen), a part of the screen stops working, like a little bar in the middle of the glass, but only that little section stops working.
To make it to work again, I have to turn off the device, wait a few hours, then turning it on again and the cycle repeats itself again and again.
What I already did was cleaning the pins and connector from the digitizer with alcohol (It works with a cheap-ass tablet I had) but no luck.
Pd: I can upload a video later on the behavior of this issue, if it helps.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Although i havent worked on Huawei phones before, as a general rule issues where a screen works for a while and then stops means the circuit in the lcd itself is bad and it needs a new screen. I cant guarantee this is the issue, but hopefully this helps you get a little closer to a solution.
Update (06/03/2018)
Apologies. I read that wrong. I thought you said lcd. If u tried cleaning the connection off then you probably need a new digitizer unfortunately
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Noah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 65
