주요 콘텐츠로 건너뛰기
2009년 3월에 소개된 The Mac Pro (Early 2009)는 Intel Nehalem 아키텍처를 Apple의 전문가용 데스크탑 라인에 도입하였으며 미묘하게 재설계된 내부는 2010 및 2012 CPU 업데이트를 통해 소개되었습니다.
202 질문 전체 보기
Mac Backup Software -Backup 2 internal HD's scheduled full/incremental
Hi,
Can anyone recommend good Mac Backup Program to backup 2 internal hard drives in Mac Pro. Time Machine only backs up operating system drive and can't specify other internal drives/folders.
It needs to be scheduled and do full and incremental backups of the 2 internal hard drives to an external hard drive.
Any suggestions much appreciated :)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Since you need to schedule the backups at a specific time frame the best option would be Carbon copy cloner. The app is $30 but you can schedule backups anytime and it has alot more options than Time machine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
So with Carbon Copy Cloner you can just backup certain folders from various internal/external hard drives without the need to do clone backup?
I would recommend a proper backup app ‘Cloning software’ is an imager app that makes a full image of the drive (partition) to a second drive so all of the data is moved en-mass to the second drive. This is very heavy processing wise and can wear the drives if used as a backup solution daily!
댓글 달기
Here’s one app: Get Backup Pro It offers a full suite of options.
I prefer syncing apps which are much lighter in process load and take a lot less time! This is what I use: File Synchronization. I have a Mac mini which is my server which all my systems use for a backup end point. I have folders which are unique to a given system and other folders which have the same data across all of the systems. I’ve been using it for a few years so I’m invested to it.
I still use TimeMachine for a backup of my basic system config so if I kill my systems boot drive I can rebuild quickly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Adrian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 48
30일 전: 79
전체 시간: 1,232
