Head lights work but no low beams
2002 Ford Escape. Hi beams are the only thing that work. Low beams don't. I have changed bulbs and fuses, and switch. Is there a way to find the hi beams until I can figure out what's wrong and fix it?
좋은 질문 입니까?
좋은 질문 입니까?
So either the light switch is bad or you may have a damaged wire. I would start using a volt meter to see if your getting power from the switch first then if that's okay start looking for a bad wire. Have you tested the bulbs to make sure they work. Using a jumper wire to the low beam wire to the battery will be an easy test to see the lights work
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 24
전체 시간: 320
