주요 콘텐츠로 건너뛰기
The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
24 질문 전체 보기
life expectancy of each battery
My cellphone just switched off on its own and wont respond even when i try to put a charger on,it looks as if the is no battery at all .Im now wondering if this has anything to do with the battery at all because i've had this Blackberry Classic since 2014 and i've never changed or touched its battery,is it dead just like that without warning orcan i change the battery?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Battery's are typical only good for a couple years then they really start to show there age. If the phone is doing nothing while plugged in it could be a board issue though. If the battery is easy to change that would be the first and easiest thing to do. If that doesn't work its time for a new phone.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
swmcitakali 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 245
