주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for laptops manufactured by ASUS.
2524 질문 전체 보기
Need Asus rescue password for 2018 06 03
I need rescue password for 2018 06 03
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 18개
Ignore the year, confirm the date and try this list of password
2008-06-03 A0AA2CAA
2008-06-04 AA1AAALA
2008-06-05 AA49OA0B
2008-06-06 AAAOABAL
2008-06-07 A2BBBALD
2008-06-08 AHBA1L0D
2008-06-09 ABDBABAB
2008-06-10 A0DBABDB
2008-06-11 ABABOAL0
2008-06-12 AA1AALAL
2008-06-13 AA0CBBDB
2008-06-14 ABAO1BL2
2008-06-15 BHOBAAA1
2008-06-16 BA0A0HD1
2008-06-17 LADLA1LC
2008-06-18 L1AB4AA9
2008-06-19 DO1A9BDB
2008-06-20 AOCA1HBA
hi guys.
I have asus x541u notebook.
iam trying to bypass the password. I have pressed alt+but there ishould no change on the screen. it still says “enter password”.
i have the exact same computer and problem, alt+r does nothing and theres nothing else i can do because the password comes up right away as soon as the computer is turned on, anyone know a solution
Pls I have Asus f541uv and alt+R doesn't work who can help?
댓글 13개 더보기
댓글 달기
답변 5개
가장 유용한 답변
Hi All,
For those having password issues,
Please visit this link below.
https://pastebin.com/L3c3rySj
OR
http://biosbug.com/asus.php
Subtract current year and get the password
e.g.
2018 - 10 = 2008
2017 - 10 = 2007
.. etc
For example:
  • At the password prompt, press alt+r
  • Take note of the date displayed. For me it was 2017-05-11
  • Use Ctrl+F to search the paste bin for your month and date. I used "-05-11"
  • Use the codes you find until one of them works. Mine was the same code as 2007-05-11 from the paste bin.
  • It looks like the codes might repeat every 10 years. So I would suggest starting with the month and date combination from 10 years prior to whatever date is displayed after you press alt+r.
해당 답변은 도움이 되었습니까?
점수 5
댓글 3개:
My date range falls just outside the data in the list - 2012 01 01.
Any advice appreciated.
Thanks ! This solution works !
Perfect! Thanks man
댓글 달기
There is alot easier way to enter the Rescue Password. If no date appears when pressing the ALT+R keys follow instuctiond below.
E.G.. date being 31/10/2018 go back 10 years to date 31/10/2008 & enter Rescue Password listed beside that date.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
no date come up
In some models, no date shows up
Please I need a rescue password with 2012/03/15
Hi Need r/pass for 07/05/2023
댓글 달기
I need a rescue password for 2012/02/11
해당 답변은 도움이 되었습니까?
점수 0
댓글 18개:
Try this 0CABAAL0
Date change to 2012/02/24
2012-02-24 1accalaa
2012-02-25 caoodabb
2012-02-26 caba1bbl
2012-02-27 92aaalad
2012-02-28 90blb9bd
2012-03-01 daab1bla
2012-03-02 daoaaaba
2012-03-03 b20cbdaa
2012-03-04 bhdoabla
2012-03-05 ababao0b
2012-03-06 aa1a9aal
2012-03-07 410lb0ld
Rescue password for 2018/08/13 ?
rescue password 2018/08/16, please help.
댓글 13개 더보기
댓글 달기
Hello, i have the same problem. I took apart my laptop to remove the little battery to reset the date. Now the date is 2012/03/20
When i try the code put up for 2002/03/20 it keeps saying its invalid. I tried the one from a day earlier and a day later aswell. I also tried changing the date in my windows to 2002/01/02 and using the password for that.. but when booting the password was still for 2012
Any suggestions please?
Much appreciated..
Update: so i changed the date to the one of today.
2019/01/13 wich worked because i booted to bios and hit alt+r and it asked for a password for that date. So i went to the bin and looked up the code for 2009/01/13 and it didn’t work. I even tried using o of 0 to make sure i didnt type it wrong the first time.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I dint get a date under rescue password so what can I do
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eric Gummeson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 46
전체 시간: 22,094
