주요 콘텐츠로 건너뛰기
귀하가 알고, 필요한, 커서를 움직이는 기기입니다. 여러 종류의 마우스 수리 정보.
484 질문 전체 보기
My Cursor is not moving! Please help! SOLVED
CURSOR NOT MOVING.....:
Model of GAMING Mouse: Alcatroz X-Craft AIR TRON 5000
Note: Wireless Gaming Mouse (With a USB to connect with Laptop or whatever)
Description:
Sooooo 5 minutes ago it was working well but the next second the cursor was stuck. I ignored the problem because this problem also took place before but the cursor started moving after a short time. But this time it didn't move. My laptop's touch pad works 100% correct and so do the USB ports. My mouse's (the one which is not working) Left Click and Right Click button work, the forward and backward button also and so so the charging. The LED Lights turn on disguising me: "I'm Working Well". After connecting the USB the notification in the corner appear with "Device is setup and ready to go" written in it. Please help me. All the port are working well. Keep in mind that the mouse also doesn't work on any Laptop/Computer, but all the buttons work.
Windows edition:
Windows 10 Pro
System:
Processor:
Intel(R) Core(TM) i5-4200M CPU @ 2.50GHz 2.50 GHz
Installed memory (RAM):
4.00 GB (3.88 GB usable)
System Type:
64-bit Operating System, x64- based processor
Pen and Touch:
No Pen or Touch Input is available for this Display
Note: Feel free to ask any questions
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi @mighty2gamerz
Is your mouse still covered with warranty? If there is, send it for service.
Most probably as you described, on different pc but same issues, there is issues with the mouse.
else if there is no warranty left, open up and inspect the mouse mainboard.
I have a feeling the optical sensor is not pickup up the captured movements.
This can be due to defective optical sensors or components which cause the sensor not to be working properly.
If possible, share some internal pictures of the mouse.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi @augustine
Thanks for the support. I commented that a long time ago so I found the problem. The problem is with the Optical Sensor.
Thank You so Much
Have a Nice Day
How do you even open up the mouse?
댓글 달기
The only thing I can suggest is change the batteries for fresh new ones , I hope this helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hi @Rob Woolcock
I found the problem. Its with the sensor. Probably gonna take it to someone to get it fixed. Anyways, Thank You SO MUCH
Have a Nice Day
How did u fix it I’m still having the same problem with the same mouse
댓글 달기
same problem,eventually after adjusment of cpi it will not work for a long time, there will be just a time that it will work,then after adjusment again of cpi it will not work again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MightY_GamerZ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 23
전체 시간: 2,955
