주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
IP 5s wont stop vibrating after waterdamage
Hi,
I got this small project going of an Iphone 5s that got dropped in water.
First i took out the logic board. cleaned it as best i could. Only didnt take of the shields ( idk. how).
After that I tried to put it on. At first sight all looks wel, only the vibrator keeps going non-stop, i tried switching it with another one that works. Still the same problem. Do u think its damage on the logic board under the shields ? and is it possible to take out the vibrator ? Or wil this make the phone work incorrect ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If it's a small project and you don't need the phone urgently I would consider doing things properly, i.e. removing shields and cleaning the logic board thoroughly with isopropyl alcohol >90%. Without a good clean chances are your phone will be short lived, maybe weeks or months but if any liquid got under the shields corrosion has already started and will continue eating up components and power rails. The vibrator can be removed, but fact it's always powered means you got a short somewhere. I'd check the switch and try replace the flat cable connecting it to the logic board in case the cleaning doesn't solve the issue.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
If I remove the shields, do i put them back on after ?
Kind regards
Sure that would be best..since the phone is yours if you don't feel safe with resoldering them in place you might consider simply glueing them back.
댓글 달기
귀하의 답변을 추가하세요
Rowland Malherbe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,975
