주요 콘텐츠로 건너뛰기
The BLU Life XL can be identified by its model number: L050U. This smartphone was released January 2016, has a octa/quad core processor, Wi-Fi capability and a 13 mega-pixel rear facing camera.
Charging Light on when not charging, phone unresponsive
My BLU phone hasn’t been responsive all day, was working fine last night, put it to charge before I went to bed, woke up this morning, when I unplugged it, the blue charging light was still on, and the screen was dim. Can not reset it, phone is unresponsive.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
In my experience when I met similar problem in samsung device I changed the lcd and worked fine. When I me this issue in Motorola device it was motherboard issue. Good luck with this device
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this same problem with my BLU Studio XL 2 phone. I solved it by removing my battery, waiting 10-30 seconds, and then putting it back and turning my phone on.
First, remove the back panel/ cover of the phone.
Since my phone had a built in battery, I needed a 000 Philips screwdriver, which I found at Radioshack as part of a kit. The same kit I used can be found on Amazon:
https://www.amazon.com/iFixit-IF145-348-...
After removing the screws, I used one of the little blue plastic triangles to remove the mid-frame of my phone.
I removed the battery, waited about 30 seconds, then put it back in my phone, along with the midframe, the screws, and back panel.
I pressed the power button, and my phone turned on!!
It worked normally.
'''My suggestion to prevent this happening in the future is to not shut down the phone while charging.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nick Gazerro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 3
전체 시간: 516
