주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
164 질문 전체 보기
Any way to read part of screen that’s broken during Apple HardwareTest
So I’m working on this reclamation project for this 13” 2010 MacBook Air. About 1/4th of the screen is broken, so normally I have it hooked up to an external monitor, which works fine.
Problem started when I replaced the keyboard recently after it’s power key stopped working. I did the replacement fine, the keyboard now works, but the computer is ghastly laggish when it’s doing anything.
I burned Apple hardware test onto a bootable USB, and ran the diagnostic, but the error code that it spits out is half-blocked from the screen damage. Bc it’s in AHT, the external monitor doesn’t work, and I can’t move the window to where I can see the whole code. All I can make out is “4SNS/1/40...” and that’s all I can see.
Is there anyway to figure out what the rest of that code is? I can’t seem to select text so copy and paste doesn’t seem to be an option either.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
가장 유용한 답변
Print the screen or capture the screen and then print it.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
I may be wrong @mayer correct me on this , but if you start the macbook up in clam shell mode you can see the diagnostics on the external display.
https://support.apple.com/en-gb/ht201834
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
vinet09 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 20
