주요 콘텐츠로 건너뛰기
모델 A1046 또는 A1095 / 1280x854 스크린 해상도
118 질문 전체 보기
질문 마감됨
Can I exchange female power
Power isn't reaching the computer. The female port is a little loose (This model a1046 doesn't come with the magnet on the power plug). I also have a broken m6497 Ibook with a similar power port. Is it possible to switch these. I'd love to get the Powerbook (a1046) running again.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
That procedure is not possible because of the physical differences in the DC-in boards themselves. Although they both operate off the same AC-adapter, the internal circuitry and cabling will in no-way match between these two computers. Sorry :(
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
It looks like Brady is correct. The PowerBook DC & Sound Cards are much different than the iBook G3 12" DC-In Board.
댓글 달기
According to iFixit's part finding wizard, here's the part you need for your A1046:
[연계 제품이 누락 또는 비활성화 됨: IF154-008]
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Yes I've done this, be sure that you remove the battery before working on it, and secure the board with the right size screw.
Good Luck,
N.
해당 답변은 도움이 되었습니까?
점수 -4
댓글 3개:
Just to clarify, you put a PowerBook G4 15" Dc-In Board into a 12" iBook G3? I didn't think the DC-In Boards were cross compatible between those two laptops.
This is definitely NOT possible. The DC-ins of these machines are completely different.
No! - OP said "Ibook with a similar power port." I said I'd done that.
There seems to be a lack of clarity as to what comments were made by whom and it what order.
N.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 806
