이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 3개:
Hi Isabel,
We will need more details, such as: Does it charge? Do you know the charger works? Is there any physical damage you can see? Have you dropped it in water? Etc.
No water, does not charge, No dent, chargers all work, no sound, a dim light that makes the screen dark grey as oppose to black when I press on the power button .
Hi Isabel,
Best Regards,
Drew
Drew Canada 의
it fell on a shaggy carpet from 2 feet It was used as tag, maybe that helps you further?
Niels 의
ThankS a lot
Isabel Tremblay 의
