주요 콘텐츠로 건너뛰기
The fifth-generation Volkswagen Jetta was introduced in January 2005.
28 질문 전체 보기
Tire Pressure light is on, even though the tires are full of air
Out of my manual, the signal is on when i turn the car on, and it stays on meaning there is a malfunction in the system, no message pops up only the low pressure indicator.
Tires are as follow: 36 - 35.5 || 36 - 25
Tire recommended: 34 psi || Front + rear.
*Not sure if having a higher PSI will trigger a warning or not
  • Not sure if the car is checking the pressure in my spare tire or not
  • I DO NOT have a reset button in my glove box, keep in mind i have a 07 VW jetta.
  • i believe the person i bought my car from changed the tires to slightly larger ones, so i don't know if i need more or less PSI
so
*Does my 07 jetta check the spare?
  • is there a reset button some where on the older ( 07 ) models i don't know about?
  • i will lower the psi to the recommended 34 to see if that helps, and check my spare and will update this post afterwards
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Does the indicator blink on and off before turning solidly on? If so you might have a fault with the TPMS system.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
VenKazi Productions 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 738
