Ts0S Memory Bank Proximity Sensor error
Hello
I have a unibody MBP Mid 2010 which was brick for a long time about the Graphic Card Issue and Kernel Panic and Shutdown (which is very common to this machine)
Recently I came across the info about faulty Capacitor and replaced it with a new one. After 4 years my machine works again ;)
Unfortunately the machine is very slow now although it has 8GB Ram and SSD. After a long research i understood that some sensors were not behaving as expected and sending out -127C as the reading which makes the CPU run at 800Mhz
The mentioned sensors are Th1H Th2H and Ts0S
I found Th1H and Th2H on the board and ordered new parts.
Yet again I could not find where Ts0S is on the logic board. What is this part and how does it work and how to replace it?
Any ideas?
Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
