주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
battery does not charge
when turned on get message that battery is low. Battery indicator indicates charge is low. Have tried to charge via 2 different usb port connectors and 2 wall adapters but do not get the battery icon to show it is charging and after trying both methods to charge stll does not show it has charged.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Have you tried charging it overnight? Sometimes batteries are severely depleted. But if the battery still gets no power to it, my recommendation is to replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
also clean your dock connector and make sure that you have a good USB cable. Check the dock connector for debris corrosion and bent pins.
댓글 달기
답변을 추가하세요
manuelo249 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 901
