주요 콘텐츠로 건너뛰기
Repair guides and support for electric and gas powered high pressure sprayers, sometimes known as power washers.
36 질문 전체 보기
Where can I get a CleanForce CF1800 HD repair manual?
Where can I get a CleanGorce CF1800 HD repair manual?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
There is none. I had to trash mine and buy another. I believe my unit had a bad internal termistor because it would cut off like it was overheating after only a brief use, then allow me to restart after several minutes. This time I went with a 2000 psi RYOBI from Home Depot.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I had the exact problem you mentioned. I finally did the same thing you did. I trashed the CleanForce and replaced it with a different washer. Thank you for your response.
댓글 달기
귀하의 답변을 추가하세요
Donald Donald 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 20
전체 시간: 495
