주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2694 질문 전체 보기
Why doesn’t my Battery Health (Beta) ever load for me?
I have recently updated my iPhone to iOS 11.4, and was excited to see my battery life because I’ve been meaning to get it replaced. I wanted to see my percent out of 100, however I cannot. Every time I open that section, it never loads for me. When I asked my mother once to check hers, hers loaded right away. To see if it needed more time, just last night I left it on overnight, and nothing ever loaded. How do I fix this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
선택된 답변
First, for the sake of it, go to this page on the Apple website and input your serial number. You may be eligible for a free battery replacement.
As for your battery health, try to put the iPhone in restore mode. Leave for 5-10 minutes, then force restart it and see if it identifies the battery.
- To put it in restore mode: turn it off, press and hold the home button (for the 6S or older models; newer models require a different approach); while holding the home button, plug the iPhone in your computer. The iPhone will restart and show a cable on the screen.
- To exit restore mode / force restart your iPhone (6S and older): press and hold power button + home button until the iPhone turns off then back on and the apple appears on the screen. Then release the buttons and wait for it to finish starting up.
A word of advice: pull a back up before doing this procedure in case something is messed up and you brick the software. You could always restore it, but your data will be lost if you don't have a recent back-up.
Let us know if this helps.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Also read these and see what Apple did things to slow you down.
https://www.macworld.com/article/3245168...
https://www.theverge.com/2018/6/19/17478...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
@hayley777 please did the first answer work for you,
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hayley Lunsford 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 40,654
