주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Killing batterys unexpected shutdown at around 50%
Hi I have a iPhone 6s plus that I have had to replace battery around 8 times as the battery works fine for around a month then dies at 50% like its flat pug it in I get 50% than continues till the battery is completely drained replace battery then like new for another month it's be like this since it was stolen from me and I got it back smashed now I'm about to replace the U2 Ic but I want to no if anyone knows of any other chips that can cause this so I can repair
Update (06/29/2018)
Hi again I'm really stuck with this one I have replaced Tigris Ic mosfet ic tristar ic I'm unsure if it's fixed the shutdown issue yet but in addition to that I have released its going through power like nothing one hour YouTube video used about 30% so I looked at big pmic and found caps c2016 c2013 c2017 c2020 c2014 c2015 c2019 and c2021 all to be shorted can anyone help with this issue as I'm sick all I can think of it replace the pmic and no sines of water damage or corrosion gave it a ultrasonic bath
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
In addition to replacing the U2 IC, I would recommend inspecting the board under a microscope to look for corrosion or deposits (as a result of water damage) that could be shorting out connections, this would lead to excess battery drain. If there is corrosion/deposits from water damage, the first thing I would recommend is a good cleaning.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
dylanrichter44 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 115
