주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1502 질문 전체 보기
Camera not working shutter stays closed
When I go to the camera app the shutter stays closed and does not open whats wrong?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
My problem,,, camera takes selfies but will not point outward
댓글 달기
답변 7개
선택된 답변
have you dropped the iphone? sounds like the camera needs replacing, but first I'd try a hard reset.. hold home and power together for 10 seconds until the apple appears and then release buttons and allow to reboot.
If this doesn't work then I'd look for a new part (fairly cheap) and follow the guide here iPhone 3GS Camera Replacement
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Did all this & even replaced with new phone!! Problem came with transferring all my contact inf
Waiting for answer or idea
댓글 달기
change the camera fix solution. work 100%
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I too had this problem, turned out connector wasn't in properly on back of logic board. Refitted it put it back together now works perfectly
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
my camera strip will damage, then I'll change the camera but shutter not open
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my shutter on my 3gs is stuck on shut, tried all the surgestions available even striped my phone down to the bare bones, Nothing, so bought a new camara and guess what, NOTHING, STILL THE SAME, seems like no one seems to know what causes it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
did u restore iphone?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This was driving me crazy for the longest time. I've tried many things but what worked for me was to just keep your browser history cleared, any cache as well. My cam has been working reliably ever since. This may not solve your problem, but it might! Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jared 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 15
전체 시간: 39,128
