주요 콘텐츠로 건너뛰기
Repair information for standalone freezers.
192 질문 전체 보기
Freezer doesn't work properly. Not cold enough
My samsung upright refrigerator has the freezer in the bottom. It stopped working but the fridge part is working well. Actually the freezer becomes a fridge. Don't know why. We unplugged and kept it off for 24 hours, but problem still there. However, if we "power freeze", the freezer will work until we turn off "power freeze" button.
Not sure what to do by myself. Do I need to buy a new one?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 4개
Please give us a model number. Usually the freezer is used to cool the fridge.
It’s Samsung RB196ACBP. And 7 years old.
I have the same probleme inmy freezer
Beko RDNE500K21W
freezer not cool not snow freez only working
댓글 달기
답변 3개
가장 유용한 답변
The most common cause for this condition is a problem with the defrost system.
I would replace the defrost thermostat: https://www.repairclinic.com/PartDetail/...
해당 답변은 도움이 되었습니까?
점수 2
댓글 8개:
Thank you. I will try to replace it by myself. Don’t know how to start. First locate the thermostat, then buy the part and replace it.
is the right part in your link that I need to buy? Normally where is the thermostat? Thank you very much
yes. that the correct part for your model. As to where it is, I think my link has a 2 min video of how to install it.
Yep, here it is: https://www.repairclinic.com/Video/Video...
Thank yo mayer. I will give it a try
HI Mayer, Just want to know, is this part you mentioned for my Samsung fridge. Should it be defrost thermostat DA47-00243K? my fridge isSamsung RB196ACBP
댓글 3개 더보기
댓글 달기
Take a look at this article:
https://www.networx.com/article/why-is-m...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This problem recurs in my fridge/freezer and I resolve it by taking out the inner panel of the freezer compartment to expose the freezer unit at the back of the freezer. This unit ices up occasionally and becomes a solid block of ice, the result of which is to severely impair the function of the freezer. Defrost until there is no sign of ice between the freezer pipes and fins etc, replace the cover and switch on. In my case with a Beko freezer, this does the trick and it works like new after defrosting.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you. i will try to melt the ice and replace the cover.
댓글 달기
귀하의 답변을 추가하세요
Min 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 16
전체 시간: 1,007
