주요 콘텐츠로 건너뛰기
AirPort Extreme 베이스 스테이션과 함께 출시된 이 하드 드라이브 장착형 제품은 Time Capsule NAS에 802.11ac 속도를 제공합니다.
56 질문 전체 보기
Hard Disk Replacement - with 2.5" drive
Hi Guys
Quick question here to see if anyone else has considered (or already completed) an upgrade on their 4th gen. Airport Time Capsule using a 2.5" drive?
I'm keen not to have trim the rubber to upgrade my 2tb drive, and have found that I can now purchase a 2.5" 5TB hard disk cheaper than I can a 3.5" drive. I'd fit it using a 2.5>3.5" ORICO adapter which should fit snugly.
My theory is that this will be good for cooling, and that the speed of the connection means that the 5400rpm drive will be ample, but I'd be really interested in everyones thoughts, warnings or opinions, as the decision seems too obviously easy at the moment, there's always a draw-back lurking somewhere!
Thanks!
Mike
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Mike,
From past experience with 2.5’ drives, they tend to be a little less reliable. 3.5’ also then to offer a slightly better performance. Also consider this is going to be an always on drive so best to look at the slightly more expensive option of 3.5’ NAS based drives. Fitting wise, unless you’re moving the thing about a lot or intend to put it in a busy, vibration prone environment, I’d probably say a small amount of double sided tape would work just fine too. Neither option of drive is the most idea as mechanical drives are the most reliable but they do offer the size. Hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mike 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 402
